10% Ethanol?
Old Feb 11, 2007 | 07:42 PM
Gordon0652's Avatar
Default 10% Ethanol?
I was filling up my 00 t/a ls1 and the gas pump said 10-20% ethanol per gallon, is that bad for the engine, anything negtive about it?
Thanks!
Old Feb 11, 2007 | 07:46 PM
spy2520's Avatar
my gas mileage has gotten worse since the area i am in now only has E10...emissions probably better though, like i give a **** lol...
Old Feb 11, 2007 | 07:49 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
We've had E10 here in the midwest for as long as I can remember. That's all you can buy here. Hasn't caused any issues for me.
Old Feb 11, 2007 | 08:05 PM
2001NBMZ28's Avatar
10-20%? Don't they know? Can't wait for that stuff to get down here - is it 93?
Old Feb 11, 2007 | 08:25 PM
SLVR_99-Z's Avatar
thats about all you can get around here. 92 octane 10% ethanol. there is one station that i know of that sells 93 with not ethanol but they charge about 30 cents more a gallon for it than everybody else. it doesn't really bother me though because they have had it around here for as long as i can remember. i don't notice a difference any more.
Old Feb 11, 2007 | 08:26 PM
JerseyLS1TA's Avatar
I noticed when i drove down to FL. in Nov. that B.P gas stations han 10% and my highway gas mileage wasn't as good as it was up north even though I was driving the same. I was wondering if that was bc of this.
Old Feb 11, 2007 | 10:24 PM
EchoMirage's Avatar
10%, and E85 ethanal, actually makes less power and less mileage then real gas. it takes more fuel to produce the same amount of power that gasoline would make. theyre using it just because it uses less gasoline, regardless of the power or mileage. so an E85 motor running just E85 would make less power and get less mileage....but its supposed to be cheaper then pure gas, and uses less actual oil/gasoline
Old Feb 11, 2007 | 10:55 PM
VIP1's Avatar
Copy & Paste Moderator
The other reason for E10 (10% ethanol, 90% gasoline) is that it replaces MTBE which is bad for the environement and difficult to cleanup.
Old Feb 11, 2007 | 10:56 PM
VIP1's Avatar
Here are some recent threads on the subject:
https://ls1tech.com/forums/general-lsx-automobile-discussion/559704-help-getting-piss-poor-gas-mileage.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/628214-what-gas-should-i-use.html
(talk about ethanol begins on page 2)
Old Feb 12, 2007 | 11:14 AM
RPM WS6's Avatar
Here in the upper midwest, you can get 93 octane all day long from any major station, but it's all E10.
Old Feb 13, 2007 | 04:31 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, think about it this way. Ethanol and Gas mix a little better than oil and water, but not by much. If you end up getting the top of the tank at the station, there is a lower % of getting as much ethanol, and vice versa for lower levels in the station's tank. But, I do not remember which one is lighter than the other. Either way, they do not mix very well at all.
