Are the reinforced gaskets reusable?
I've noticed that some of the gaskets on these engine are reinforced with aluminum (namely the oil pan and timing chain cover). Do these gaskets need to be replaced when doing a head/cam swap or are they OK to reuse? If the oil pan gasket has to be replaced, would anyone have a part number it? Thanks.
If they look decent, ie not ripped or torn (obvious), they should be fine. The only gaskets that really need to be replaced are the paper ones like the water pump gaskets on the 1998 model year cars. And you can replace those with the metal ones.
Now if you were building a motor from scratch or doing MAJOR renovations to it. I would just opt for new gaskets for peace of mind.
