mod or not to mod
Maybe i am just being crazy i know that i should not worry about what power and times the others make. But it does suck being last all the time i do have a 02 auto with subframe connectors, strut tower brace ,bmr 1 inch lower kit, air lid. with a ls1 hot cam kit in the box never put it in and under drive pulley sitting with it
what do you guys think should i compete with the others for good times and power or just keep it stock with stall and gears
i say stay with stock block and mod i'd say sell the hotcam (or return if you can) and buy a better and/or larger cam.
install the u.d. pulley. purchase/install longtubes, and true duals.
dont skimp on the converter... put atleast a 3500-3800 verter in it.
and get a good tune. the car will rock, even with stock gears/heads.
and if you just need to have the power to get to the head of the pack at the car shows/cruises... then slap on a 150shot.
problem solved. you're welcome.
lol
, and if you got the cash, H/C would be a nice idea, then you will be right there with them without the n2o...full bolt ons and H/C, you should be right around...400-440 RWHP, correct me if im wrong, and if you keep the 150 shot, ya know maybe an extra 80-100 at the wheels.... so you should be beating them... The Best V8 Stories One Small Block at Time
This is my main problem. i dont have the knowledge i dont know the heads weak point and the cams strong point. i know you should match them together and this is where i get lost and confused. at first i was just going to just put the hot cam in and cat back syst but wanted heads.
https://ls1tech.com/forums/showthrea...ghlight=thread
Then ask yourself where you stand.
Major mods all have their ups and downs. It's in your best interests to really decide for yourself prior to doing major mods whether you can live with the potential downsides. For a daily driver, this consideration is even more important.
When my local club was at it's height, I always used to tell my guys not to go nuts modding the car they count on to get back and forth to work everyday. And of course, most of them didn't listen..... and most of them had issues that became a big problem when they found themselves without a mode of transportation.
So in the end, ask yourself: Can I afford a lot of downtime if something goes wrong? If the answer is no, then consider first buying a daily driver before you shoot for 10 second time slips. If the answer is yes, then the only other question you have to ask yourself is, can I live with some of the negative side effects of certain mods? To answer that one, you need to do your best to investigate your planned setup and see what issues others have had that took the same path you're planning now.
Money is also a consderation, daily driver or not. Can you afford what you want to do? And can you afford to fix the stuff that might break when you start racing it?
Modding can be a fun, great, cool experiance if you do it right. Or it can be a major pain in the *** if done wrong. Just make sure you think through what you want, what your budget is, and what your goals/expectations/limitations/tolerations are before you start ordering parts.
Read, study, investigate, ask questions (as you currently are), listen/read and FULLY consider the answers of experienced modders, and plan ahead. Foresight and comprehension will be your best friends when it comes to planning a course of mods for your car that you can live with, afford, and have a good time while doing.
Good luck, and have fun.
SEE....MOD IT!!!
