question about a vibration
Old Mar 3, 2007 | 04:58 PM
moondoggy1302's Avatar
Default question about a vibration
I got a 02 z28 a4, every time i get up to about 60 and let off the gas it has a very annoying sort of shutter. it almost feels/sounds like the driveshaft is off balance but i have no idea. It only does it from about 60-75 anything over or under makes very little if any vibrations. I just thought id get your guys ideas about it before i go to get it checked out and fixed, its very annoying so im open to any ideas. It doesnt affect the performace of the engine at all though, it ran 13.5 et a few weeks ago bone stock. thanks for the ideas.
Old Mar 3, 2007 | 07:19 PM
cowboysfan's Avatar
check motor/trans mount. check drive shaft U-ny joints. u mentioned you were at the track a few weeks ago, check tq arm/bolts for cracks too.
fuerzaws6
Old Mar 4, 2007 | 03:08 PM
BlueZ35th's Avatar
is there still wheel weights on the wheels, have your wheels&tires balanced.
Old Mar 4, 2007 | 03:50 PM
StripedZebra's Avatar
Is it like this http://video.google.com/videoplay?do...00636130&hl=en
Old Mar 4, 2007 | 09:57 PM
Rede's Avatar
If it was a ballancing problem.. wouldn't it get worse the faster he went considering how the wheels are rotating that much faster?
Old Mar 5, 2007 | 03:54 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
fuerzaws6
+1 for trany mounts
Old Mar 5, 2007 | 04:17 PM
*bump*.....
Old Mar 5, 2007 | 09:17 PM
98Camarod's Avatar
You only have to have the fronts balanced. The reason why the rears are balanced is for rotation purposes. It wouldnt hurt to have your front wheels checked to see if they were balanced. Check your mounts and u joints like mentioned before.
Old Mar 6, 2007 | 12:31 AM
Fifedogg's Avatar
I would try the driveshaft/U-Joints and also the trans mount. I know Lt1's were always doing this but your car has an aluminum DS.
Old Mar 6, 2007 | 04:38 AM
Rede's Avatar
Originally Posted by StripedZebra
Gah.. that'd drive me nuts.
Old Mar 6, 2007 | 12:38 PM
Cocheese's Avatar
I had the same issue in my 94 z28 a4. But it had the steel driveshaft, which were notorious for going out of balance. It did the exact same thing though, vibrations from about 65 to 80. Anything over or under were pretty smooth. I'd definitely check the drivetrain out, from the tranny back.
Old Mar 6, 2007 | 03:25 PM
no its not near that bad, it doesn't make any sound really at all when accelerating and you can really hear it to much, Its just a vibration, its not like crazy loud to where it makes my car undriveable like the video, its just I drive 7 or so miles to work on the freeway and thats when its irritating. So should i take it to just a normal car repair place or a tranny shop?
Old Mar 6, 2007 | 03:48 PM
Do a search. This is one of those repairs that you can do in your garage! .,..$$$
Old Mar 14, 2007 | 03:09 PM
ok so in the past week i replaced my tranny mount which just made the vibration worse and i just got my tires rotated and balanced and the problem has only gotten worse. any other ideas guys?
