Rear o2 same as front o2?
Are the front o2 sensors the same thing as the rear o2's? I think I have one on the way out, and have the rears sitting around from the header install. Can I use them?
Just as long as the harness reached the plug. The fronts are actually different part numbers because the LH harness is longer than the RH. If you try to switch the 2 fronts from side to side, good luck.
As ryle said above, they are interchangeable w/o any probs.
