Need serious Help
Is this true... everything on the car is stock but i still have both my cats... will anthing blow or stop working with the headers unbolted frmo the Ipipie
....thats actually pretty funny! lmao! Is this true... everything on the car is stock but i still have both my cats... will anthing blow or stop working with the headers unbolted frmo the Ipipie
The stock exhaust manifolds are pretty short and end about 6-8" down before leading into a pipe then the CAT then the Y merge collector and the I pipe.
So what exactly have you done??
It is not advisable to run no exhaust, 1st it removes harmful gases away from the interior of the car but it also is there for emissions/noise control.
The latter of which may be less important, but you won't see much gains doing what you've done.
If you want louder, get a catback. If you want more performance buy LT headers and a decent Y pipe combined with a good catback exhaust.
Did you disconnect the exhaust system at the 3-bolt flange that connects the cat pipes to the manifolds on both sides? Or did you just disconnect the I-pipe from the Y-pipe? You say you're "just running stock headers", but then you say you're still running cats. That is not possibile. Either it's headers with no cats, or it's headers with cats.
If all you did was release the band clamp for the Y-pipe to I-pipe merge, and are now dumping the exhaust right at the end of the Y-pipe, then you are not going to hurt a thing (other than maybe your hearing).
I had just straight headers for like 2 days and nothing happens, not even to my O2 sensors.
The only thing that can possibly happen is you burning your valves up due to a lack of back pressure.
If its a temporary thing, get it fixed.
Or just buy an e cut out.
But I'm still not sure about exactly what he disconnected....? He said...
So far I have figured out:
You have cats.
What did you take off exactly and do you have headers, manifolds, shorty's, mids, LTs??
My I PIPE(after the Y PIPE merge) is not bolted up(just hanging) and its the same as having a cutout thats stuck open. No Big deal.
I have a SLP Dual Dual exhaust syste,... If this helps... But all we did was take off the Y pipe....
The I pipe and themuffler is jsut hanging there... just to give the impression.. It is liek a permanent cutout...
You have cats.
Should i leave the Y pipe connected and unbolt the Ipipe or just unbolt the Y pipe?
As of now the Y Pipe is not on the car...
It will be just like running with an open cutout then
But as of now it is jsut running with an Y-pipe. The I pipe is off... and from reading.. it doesnt seem like it will cause harm besides all the black crap it will leave behind.
Correct me if i am wrong but will this cause any harm to anything?
