Timing off ??
Old Apr 24, 2007 | 09:35 AM
98_z28's Avatar
Default Timing off ??
My car does not pull as strong as it used to and my valves chatter bad. . .does that sound like my timing could be off ??
Old Jul 16, 2008 | 11:10 PM
Ego Killer's Avatar
no, sounds like your running cheap gas.
Old Jul 16, 2008 | 11:11 PM
406malibu's Avatar
which would lower timing due to the knock sensor
Old Jul 17, 2008 | 05:00 PM
NoE~DaWg's Avatar
dang, my car is doing the same thing and come to think about it, it started when gas prices started going up and I stopped pumping 91 and started pumping 87...I can't believe that makes so much of a difference.
Old Jul 17, 2008 | 05:05 PM
fuseone's Avatar
owners manual says you can use 87 but performace will be different.
Old Jul 17, 2008 | 05:50 PM
Ego Killer's Avatar
back when mine was "stockish" it ran like a$$ when I used 87
Old Jul 17, 2008 | 06:27 PM
NoE~DaWg's Avatar
lol guess I should fork over a few extra bucks and pump 91. I was gonna have it tuned cuz I thought that might take care of the pinging. I'll run 91 the next few times I fill up and see if the pinging stops.
Old Jul 17, 2008 | 07:02 PM
ItsNotStock's Avatar
I have never understood why people think using cheap gas actually saves money in the end. Up here premium (91) is $4.29 and midgrade (87) is $4.21. That is a difference of eight cents... yes eight cents. On a full tank of fuel that would equate to $1.20 I don't know about you but the extra buck is worth eliminating the pinging, and suffered performance. Unless you're tuned for something else the recommended octane for these cars is 91+ if you can't afford the extra dollar than you shouldn't have purchased the vehicle.
OP, run a scanner and see if you're getting KR. Honestly it could be a number of things mechanical. What did you do to your car recently? Any error codes? Start fueling up somewhere else and see if it goes away. It's not too uncommon anymore for gasoline stations to high-grade.
Old Jul 20, 2008 | 02:45 PM
Luder[PAK9]'s Avatar
Well, it's more like a 30-40 cent difference on the coasts. But you're right. If you didn't want to spend $$$ on gas, you shouldn't have bought a 5.7L V8.
Old Jul 20, 2008 | 04:54 PM
gymratt's Avatar
+1
Old Jul 21, 2008 | 05:58 AM
burnrubr88's Avatar
plus since the engine was made to run on 91 or higher it will perform better and be more efficient, and the improved efficiency from the higher octane will end up saving you money in the long run (i.e. more efficient nets better MPG in most cases)
