Service Engine Soon !!!!
Originally Posted by VerySlowTA
You should always assume that the people at a parts store don't know ****.
There is no way that he could hook it up to an OBD-II scanner and discover you have an exhaust leak. If your car has an exhaust leak, you should be able to hear it. There are no "exhaust leak" fault codes.
Originally Posted by angel71rs
20 bucks at Autozone, quick fix. Better than looking at that light for months.
Just replace the check valve, your light will go out. I had P1415 on my car, same code but for bank 1, got the check valve for like $12, put it in and the light went out. Even if you plan to get it tuned out, it's just $12 to get rid of the SES light. Didn't even need to reset the PCM either, light just went out after install. You can test the check valve by trying to blow through it in the direction of airflow (towards the manifold), just to rule out anything else.
Originally Posted by styoung
well i dont need a inspection sticker and are hopefully buying headers by the end of the summer so i hate to spend the money on something i dont really need. and when i buy headers i plan on getting the offroad ones.
Also, until you get the headers, just fix your car. $20 bucks? geez!!
Good luck!
Originally Posted by BAD2000TA
LOL - more tuning to eliminate the codes you are going to get! Why are you getting the offroad headers? You that running no cats is illegal and I'm pretty sure MASS has some tough emissions laws. The smell without cats, the excessive rasp, and tickets for "improper exhaust" might change your mind.
Good luck!
Good luck!
styoung, if your getting the race headers with an ORY, just **** can the AIR system now, idk what shops charge in mass., but here they will tune EGR, AIR and rear O2's out for ~30 bucks. if you get the race style headers, your going to have to get rid of it anyways, so insted of paying 12-20 bucks now to fix it only to **** can it in a few months, save the 20 bucks to buy you some gas. if you can get around the emissions checks and can live with the fact that if you get busted without them, your facing a 3000.00 dollar fine, do it. i know here in ohio, if you get busted once, you get a fix it ticket, and twice, you get slapped with the fine. now on the other hand, if your going with a catted Y-pipe, keep the AIR system, or your new cats will go bad in a matter of months.
ORY=no cats and shitcan the AIR system now and have codes deleted
Catted Y=cats, and fix AIR system.
Good luck!
Good luck!
Tech Resident
well just got back from the zone and got the code P1416, says air system bank 2 fault. i guess this means its time to remove the air pump. any ideas? thanks
i guess i'll just pick up a check valve from napa. it's only $13 for them. i always forget, bank 2 is pass. side, correct? i hate emissions equipment
well last night i was driving home from my friends house and i pull on the highway like i normally do, 20-70 as fast as i can, and i set my cruse control and i look at my dash and the service engine soon light was on. so i went right to autozone and had them scan it and he said that i had a small exhaust leak. now i checked my exhaust over today and didnt notice any leaks. but i know that i have had a rattle in my muffler getting worse. could a bad muffler cause the ses light to come on?? o and all i have done to my exhaust is a hooker catback. any input would be nice. thanks.
There is where I bet your issue is. It will be throwing a sensor II bank 1 or II "low sys. voltage" code. This is caused by an exhaust leak RIGHT before your rear O2. A steady SES light is indicative of an emission equipment issue. This is emissions stuff. Look at the one on your pass. side. The condensation from teh AC runs down the exhaust pipe when you stop and the place where the cat/exhaust meet at the rear of the cat is prone to cracking. I bet that is the issue. You may not hear a leak there that could cause this issue. That is RIGHT before an O2 so it doesnt take much.
Originally Posted by ChocoTaco369
lol i got this code thrown wednesday. that's so funny. SAME CODE. i had it cleared, put some techron in my tank and it didn't come back
#32
#34
Originally Posted by HIPER-Z
Sounds to me like your code was reading wrong, maybe you just need to get it deleted out.
#35
P1415 is drivers side, P1416 is passenger side. Take the valve off the car and see if you can blow air through it. Dealers will normally change both air check valves for either code, but not always necessary.
