Broke wires to sensor/power
Old May 8, 2007 | 07:57 PM
Billybob876's Avatar
Default Broke wires to sensor/power
Today I was removing my old K-Member to install a tubular one. I forgot to unplug one connector on the passenger side and the wires ripped out of it when the K-member dropped. Three small wires broke from the push clip. The part where it connects to the block is above the oil dipstick tube and you have to remove the starter to see it. Does anyone know what it is/does and how would I fix it. I'll try to get a picture up later this week.
Old May 8, 2007 | 08:10 PM
bww3588's Avatar
idk what it is, but you can go to the GM dealer and tell them what happened, and they will order you a new plug with a length of wires on it, just cut and connect the wires into the existing wires and plug it in.
Old May 8, 2007 | 08:24 PM
Syxx613's Avatar
sounds like crank sensor. make sure u solder the connections or you might not have a good enuff connection.
Old May 8, 2007 | 09:44 PM
bww3588's Avatar
they dont need to be soldered, just connected with crimp connectors and taped up. but soldering is a good idea.
Old May 8, 2007 | 10:11 PM
bww3588's Avatar
Originally Posted by GregD63
My brother broke the wire to the crank sensor on his Silverado. It would not start with the wires broken. Will your car start? He also broke the wire to the oil level sensor on the side of the pan.
Wires like that will never break where you might use a connector to put them back together. You always have to get a new wire from the dealer.
thats what were talking about. mine pulled out from the plug on the oil level sensor and i had to get a new plug with wires from the dealer. but the old and new wires dont have to be soldered.
Old May 8, 2007 | 10:35 PM
yah the car will not start. I looked through my haynes repair manual and it apears to be the crank sensor like Syxx613 said. Thanks for all the help.
