Quick intro and first question
I have had the car for nearly 2000 miles now and I have noticed a very clear and intermittent engine noise
. I posted about this on the corvette forums and I received a reply that stated that is "normal". But only 1 guy replied so I need to make sure before I poop my pants
. I am not a newbie to cars and not mechanically retarded. The most complicated job I ever did was the replacement of headgaskets... so that kinda gives you my mechanical abilities....I have owned many cars and NONE have made a noise that is similar... It sounds a lot like a pretty loud sewing machine; I know that this may be considered normal. But in my case sometimes the noise is present and most of the time it isn't. And when it is present it is loud enough for passengers to notice and ask me about the car and if it is supposed to sound like that
. Is this normal for an LS1? I mean this thing is almost new and pristine, never raced... I would seriously doubt that there are issues on hand here due to abuse. I have all maintenance records on hand as well
./end rant
Good luck and welcome aboard!
like said above, check out the top end and make sure everything is snug. if not go on a spending spree and buy me a BOV while your at it.
However, depending on the volume of the noise, there may or may not be something wrong. Is the car a manual trans or automatic? I ask because, with a manual there is a greater possibility of bent pushrods from a missed shift.
Also, is the noise present at all points in the rpm band (idle to redline)? Can you hear it when free revving the motor, or only under load?
Another thing to consider might be the oil. Any idea what oil is in there now (brand and weight)?
Many of us LS1 owners have found that using oils on the heavy side of a 30 weigh or the thin side of a 40 weight (like German Castrol 0W30 or Mobil 1 0W40 and 5W40) seem to be ideal for an LS1 in terms of wear numbers (oil sample tests), engine noise, and consumption rate.
Oil is Mobil 1 5W30, and filter is Mobil 1 as well.
Under load there is another sound coming from the shifter... only at WOT in 4th gear for example. But I think that is another issue. Engine sounds healthy at WOT. And I have absolutely no oil consumption, I got close to 6.5 quarts out after 5k miles.
