Security light
Old Jun 6, 2007 | 09:04 AM
crazy02ss's Avatar
Default Security light
I have a 2002 SS and my security light has been on for 3 days now and i read the manual and it says it could be the keys and to have it replaced has anyone ever heard of this? Also just today it started blinking and wont let it start how the **** can this be from a bad/dirty key?
Old Jun 6, 2007 | 09:24 AM
GregAbell60143's Avatar
There is a resistor pellet in the ignition key that the value of gets read. If the resistance value doesn't match what it is supposed to be, it will disable the car from starting for SEVERAL (I forget the actual time) minutes. Try cleaning the resistor contacts on your key with a pencil erasure (gently), wait 15 minutes or so, and try it again. It is a theft deterent system - they figure that a thief won't wait around trying different resistance value keys until he stumbles on the correct one (while waiting XX minutes between each one).
Old Jun 6, 2007 | 11:14 AM
LS1W66's Avatar
The car is disabled for 3 minutes then the light will go out.
Old Jun 6, 2007 | 02:51 PM
TLUZLS1's Avatar
Its the VATS system I believe. Its a PITA!
Old Jun 6, 2007 | 11:32 PM
crazy02ss's Avatar
Yeah i have tried everything i got a new key cut and it started once then wouldnt start again so then i unhooked the battery and hoped it would help and nothing still. I starting to hate the F-Body!!!! What to do next?
Old Jun 8, 2007 | 09:44 AM
The wires leading out of the steering column for the VATS are pretty small guage - maybe one of them has broken, only occasionally making contact. It is possible to do away completely with all that VATS nonsence. You measure the resistance of the pellet on the original key, and purchase a resistor of the same value. You then cut and splice the resistor into the wiring (a similar type of procedure you'd need to do if you were adding a remote start to your car). I don't have a Service Manual to tell you which two wires - you might be able to Google it.
Old Jun 8, 2007 | 07:14 PM
crazy02ss's Avatar
Would getting a new alarm work?
Old Jun 8, 2007 | 07:26 PM
01FbTaWs6's Avatar
no, it wont work. Either have vats tuned out, or do the simple resistor mod like mentioned above. do a search for vats, and you will come up with the thread. Its pretty simple man, did it to my TA also. VATS is JUNK!
Old Jun 8, 2007 | 08:04 PM
1996Formula's Avatar
my light is always on, but never have any trouble starting it.....ideas?
Old Jun 10, 2007 | 01:10 PM
ReFtheMC's Avatar
Mine Turns On Every Now And Then, Never Really Paid Much Attention To It...
Old Jun 10, 2007 | 07:28 PM
culhan9's Avatar
Not sure if heat has any factor in this problem, but all last summer it would not start. After I turn the key a few times and stomp on the clutch it would start. Now since its getting hot out again I'm having the same problem, but worse this summer! All winter I had absolutley No problems starting.
I think the resitor mod is a great idea, thanks!
Old Jun 10, 2007 | 09:07 PM
LS1tones's Avatar
That same thing happened in my old Z, GM looked at it one day when it got towed there one day and said its probably the wires in the column as they have a tendency to break or have a bad contact after a while.
Old Jun 11, 2007 | 04:14 PM
ChevyThunder17's Avatar
You can have the car tuned and ask them to turn off VATS. It will no longer be a concern. I always turn it off on anything I tune unless told not to; and it'll cause issues with certain remote start setups especially if the shop doing them has no clue.
