AEM wideband? stuck?
i had a wideband for Air fuel ratio, it recently got stuck on 14.8. i turn the car off and restart and it goes back to 14.8 again. any advice? is it broke? it was working fine yesterday. i checked the connections and it looks as if most are all connected. any advice or reccomendations?
Either the sensor is bad or the sensor connection is not correct. That is pretty much the only time the AEM will show 14.8, as it is the default when no sensor is plugged in.
i checked all the connections and everything seems to be good, i hit a really bad bump the other day i guess the sensors can go bad after a big bump in the road? i will try get a new bosch sensor, thanks
