how does the traction control work? asr?
It sounds like you are having an issue with the actual ASR switch as if it were a problem with ASR itself, it would stay off constantly. You can easily pop the center peice off from the dash to look over the switch to see if there is anything suspicious.
You can also check the ASR fuse in the fuse box under your hood, but if the fuse was bad, ASR would stay off constantly.
Hopefully that helps, if you could understand it. Works almost in the same way that the crank position sensor and timing stuff on our cars runs
