ls6 intake swap, materials needed
Scammer Alert!
ok so i am going to swap from a ls1-ls6 intake, and i wanna know what, and where i can get the extra needed accessories for the install, i.e. coolant crossover lines, egr blockoff plate, and whatever other needed accessories, thank you very much, if i have to buy from dealer, part numbers would be great
When I did my swap I called speed inc. and asked if they could price match texas speed on the price of the crossover plugs. They told me they could not so I ordered them from texas speed. I ended up taking a small electric orbital sander and just sanding off the ribs. I figured the cross over set can just wait till I move up to a fast 90/90. I vote do the rib removal.
Do yourself a favor and buy an oil sending unit... huge chance of you breaking it on accident. I did my swap on a sunday, and when it broke, I couldnt get another sensor until late monday... I think the $25 it costs is worth paying for and having JUST IN CASE. If you dont use it, you can always return it.
-My $0.02
-My $0.02
you wont break it if you unhook the brake booster hose from the brake booster before you try in pull the intake out. then, when your pulling it out, keep your hand on the end of the hose and make sure it doesnt catch. i didnt have any problems. i just found the sending unit before hand and kept it in mind.
I didn't break the sending unit either. I don't know why that's such a common problem. Maybe people are just trying to rip the intake out of there or something, but just disconnect the hose from the booster first and as you carefully and slowly shimmy the intake out, keep a hand on that hose to make sure it has some slack. It's not hard. As for the coolant lines, I didn't screw with mine. I found that using a chisel to break off the ribs on the bottom on the LS6 intake was the easiest way.
