Do i REALLY have 2.73's?
#41
The (nearly) foolproof way to determine your rear end ratio is to keep your car in your 1:1 gear (3rd or "D" on a 4L60E) and accelerate to 70MPH. Hold the car at 70 while in 3rd and look at your tachometer. If you have 2.73s and have the stock tire size, you should be turning right around 2700 RPM. 3200 for 3.23s, 3700 for 3.73s, etc, etc.
Hope this helps
Hope this helps
#43
for ******* real....screw all this RPM/speed/tire height guessing. Personally, I just put a little piece of tape on the bottom of the DS, rotate the wheel once and count how many times the DS turns over. If it goes over about 2 and 3/4ths times, then you have 2.73s
#44
http://youtube.com/watch?v=6dRf9eDBxU4
i kno my car shifts at 45 mph, its a lil hard to tell with tht video screen being small, and my shift kit kickin up the speedo a bit, but yea do shift at 45 mph, does tht mean i have 323's or could i still have 273s?
#45
i agree with the tape and driveshaft theory..but if you car is stock you can call the dealership and give them the vin number and they will tell you, or just look the code up on the door panel i beleive and it tells you all the options you have..(its on the inside of the drivers door, the sticker that also tells you the vehicle weight)
#46
FWIW I checked 3 different cars with my GPS to see how accurate the speedometer is. The other 2 cars (speed) were were exactly what the GPS said. My 99 A4 T/A was off in increments of about 5 mph. For example, when my speedo said i was doing 35 but i was really doing 30. When my speedo said 70 i was really doing 59 and at 100 i was really doing about 84. Bone stock with factory spec tires.
My point is don't get to hung up on exact RPM quotes on here.
