Header Install!!
Old Oct 6, 2007 | 10:19 AM
JerseyLS1TA's Avatar
Originally Posted by LS7jUnKiE
.....lol im glad i have a lift!
You lucky bastard so hows the install going..not looking forward to my own
Old Oct 6, 2007 | 06:53 PM
odarabla's Avatar
Default Headers are in!!
Ok, I have both headers in!! Once I got the car up a little higher it just slid right in. It was easier than the drivers side. I went to put the Y-pipe in and the damn thing is to long! So I have to pull the Y-pipe back out and cut about an 1/2 inch off of it. Which I will do tomarrow. I am waiting on a O2 extension for the drivers side. They forgot to ship one of them!! Go figure!! Once I cut the Y-pipe, it should slide right in and I can clamp it up. Can't wait to get it in and drive it. Then my converter should be in next week!! I ran a 13.6 @ 104MPH with a 60 ft of 2.1. What do you all think I should run with the headers and converter. I also changed my MAF meter because the guy that had the car before me descreened to stock one. I replaced it with the SLP 85mm.
Old Oct 7, 2007 | 11:08 AM
TLUZLS1's Avatar
Originally Posted by teke184
page 11 of this website....should help all you need:
my site
I used his write up when I installed mine. There is only one thing he left off, "re-install the dipstick". I was in such a hurry to fire my car up, I left out this common sense step, and I forgot to put the stupid dipstick back in. Talk about feeling dumb. I fire it up and it runs fine but I couldn't figure out where all this blue smoke was coming from LOL. One quart later...I realize how much of an idiot I am. Oh well, I had 6 qrts of oil and a filter sitting in the garage so I figured now was as good a time as any to change the oil... So there is my bonehead move of the century. So just remember to re-install the dipstick haha.
Old Oct 7, 2007 | 11:40 AM
IFRYRCE's Avatar
The SLP MAF has some resistors that skew your numbers and report the wrong incoming air to the computer. It'll help you lean out the stock tune a little bit, but it's not good if you're getting your car tuned. You can either take the resistors off and use the 85mm truck tables, which are pretty accurate, or you can buy a stock screened MAF (in which case, the 75mm Holden tables are more accurate than the F-body ones). I've got a stock MAF if you want to buy it, but I'd just take the resistors off the SLP one. Search around, it's on LS1Tech somewhere.
Just my 2c though, plenty of people run them.
Old Oct 7, 2007 | 07:33 PM
odarabla's Avatar
Headers and exhaust are now in after a little fabbing!! I do have a tune on the car. But the SLP cannot be hurting me more than the stock one desreened was hurting me? The car was pinging after 4500 RPM and the computer started taking timeing out. So I was already losing HP. After I get my converter installed and the cam in next week I am going to get a Dyno tune!! So I hope this will help.
Old Oct 7, 2007 | 07:34 PM
odarabla's Avatar
Where are the resisters on the SLP MAF?
Old Oct 7, 2007 | 08:15 PM
blkZ28spt's Avatar
Stick with the stock MAF! Especially with an automatic!!
Old Oct 8, 2007 | 04:26 AM
odarabla's Avatar
I cannot. The stock MAF was descreened when I got the car. It was causing the car to lean out after 4500 RPM which made the computer retard the timing to prevent the engine from pinging. This is the only reason I replaced it.
Old Oct 8, 2007 | 06:24 PM
1SPRY99's Avatar
Good Job On The Header Install!! I Just Did Mine Over The Weekend. I Fortunately Had Access To A Lift. I Put Pacesetter Lt's On And Y-pipe. Through A Dynomax Bullet Out The Back. Love The Sound.
Old Oct 8, 2007 | 07:23 PM
odarabla's Avatar
It's not very loud with the Maganaflow cat back at idle but when I get on it the thing sure is loud!!
Old Oct 8, 2007 | 09:47 PM
JScamaro's Avatar
Yea my gmmg isn't very loud at idle but when you get on it
Gj on the successful install.
Old Oct 8, 2007 | 09:57 PM
  #32
camscam02's Avatar
the stock descreened MAF was not causing that! it is something else to do with the MAF not the descreening of it!
Old Oct 9, 2007 | 04:47 AM
  #33
odarabla's Avatar
Thanks man!!
