skip shift & rpms as well
- I HAAATE the damn skip shift thing.I do have a curiousity, someone on here mentioned it's a computer aided gear selection to improve economy, but I dont quite understand, when it happens, it locks me out of 2nd, then when it will finally go in... it's lugging the hell outa the car, or you have to shift back into 1st, then the car's jerking around making it look like ya can't drive a stick, or... the eprson behind you almost rear ends you...
I am wondering that this damn thing is actually dangerous, what if you were pulling onto a busy road and the damn thing decided to come on!?!?!?!
ok, so that also brings me to a question of sorts... - what rpms do y'all shift at under "normal" everyday daily driver conditions, like no hot-rodding, just normal driving?????? - I am not used to the f-bodys, and the engine being "in the cab" so to speak with me, so when I hear the noise of the engine revving, to like 2500rpm, it sounds like 7,500 to me, just cause of the engine noise, that keeps me shifting every day around 2,000. and never ever over 3,000.
Especially also, because the car when letting out the clutch has a slight tick kinda noise, and a slight rattle at 2500 under acceleration... (apparently ls1's are just kinda "tick-ey" anyway???????)
just wondering what some others think...
If say you were pulling onto a busy road, and you were half way into it to get your speed up, the skip shift wont come on. When you have some decent acceleration going on, it doesnt try to force the shift. But its not an expensive or complicated fix buddy....
http://www.ls1speed.com/cont.cfm?cid=C0000141
even when it engages...the car should have enough pull in 4th to continue to accelerate. but yes it does bog the engine down.
by simply reving the car a bit more you'll get out of the "range" of the skip shift and it will shift fine.
as for normal shifting points. i would say i hold 1st and 2nd longer than i need to, maybe 2500 for for 1-2 and 2-3...but then i tend to skip shift and go right to 5th after that.
and sometimes i'll just do 1-2-4 since alot of my driving is 35mph, which is 4ths good spot.
Like the last response said, I still skip gears sometimes but it's at my choosing and not the computer's. Sometimes I will let it rev a little higher and do a 1-3-5 pattern. That 1-4 thing sucks though. My sister drove my car once and she went 1-2-5. She was proud of herself until I told her that she missed 2 gears, lol.
Pitbull14218: Your problem may be you are not using the accelerator enough to rev match. I can squeel the tires when I drop the clutch shifting into second. And that is when I ony shif at 3000. I don't do it all the time, just when I sift hard.
