Alarm problem -.-
Old Dec 31, 2007 | 09:08 AM
liquidsmooth's Avatar
Default Alarm problem -.-
Hey guys, I had a similar issue on my 96 camaro. On my 2000 the alarm just started working and needs to be reset. On my 96 all I had to do was pull the blue 15 fuse and turn the car to right before start 3 times and then hold in the lock and unlock buttons for 5-10 seconds to reset the alarm. On this 2000 SS I got I can't figure it out. Plus the ignition has that stupid! button you have to press with your thumb. Any help I'd apprecaite it, I tried searching but couldn't find a clearcut answer. I don't want to spend 80 bucks at chevy getting it reset. Thank you!
More specifically trying to figure out how to reset the factory keypad (lock, unlock, trunk, panic) key-ring black thingy, with the factory alarm!
Old Dec 31, 2007 | 10:44 AM
2001NBMZ28's Avatar
Not sure what you're asking - by just started working you mean it's going off for no reason a couple minutes after arming? That's usually the shock sensor going bad. If you just want to reprogram keyless entry fob or alarm settings instructions are in the owners manual, or try resynchronization. If you don't have a manual you can look at/download one at http://shbox.com/pdf/manuals.html
Old Dec 31, 2007 | 12:02 PM
Yeah I'm trying to reprogram the keyless entry, my car didn't come with an owerns manual. Thanks for the link!
