98 Head Bolt Pattern?
Ok, I've been searching and reading, but no conclusive answer:
I've heard people say that the 98 heads are perimeter bolt, but some of my searching suggests that maybe just the valve cover is perimeter bolt. Basically what I want to know is will every LS1 head bolt onto a 98 block, including the truck heads?
This is from JRP's newbie tech from the sticky above. It says all Gen III heads are interchangable, but also says that the 97-98 heads are perimeter bolt. So that means the 98 block has provisions for other head bolt holes? Correct?
Head Casting Info
ALL Gen III heads are interchangable.
Here is a list of a few casting #'s:
933 97 aluminum perimeter bolt 5.7
806 97-98 aluminum perimeter bolt 5.7
853 99-00 aluminum center bolt 5.7
241 01-03 aluminum center bolt 5.7 (some late MY00 cars got 241 castings)
243 LS6 aluminum center bolt 5.7
862 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron center bolt heads
317 01 and up LQ4 6.0 aluminum center bolt heads
035 02 and up LQ9 6.0 aluminum center bolt heads
Head Casting Info
