Overdrive
Old Mar 11, 2008 | 02:43 AM
srleadguitar's Avatar
Default Overdrive
How do I know if the tranny has overdrive or not?
Old Mar 11, 2008 | 03:15 AM
Counted Out's Avatar
I think all Automatic LS1's did.
On the gear selector, it should have a like circle around the D.
Old Mar 11, 2008 | 04:10 AM
discostu's Avatar
all stock automatic camaros have overdrive.
Old Mar 11, 2008 | 04:23 AM
2MuchRiceMakesMeSick's Avatar
All f-bodys have overdrive technically.
The fifth and sixth gears of a M6 tranny is considered to be double overdrive.
Old Mar 11, 2008 | 08:34 AM
The reason i ask is I have no D with a circle, just the D. Also, while letting off the gas in drive it sounds like a manual winding down.
Old Mar 11, 2008 | 10:16 AM
SparkyJJO's Avatar
If you have the A4 and it is stock then yes you have OD. On the shifter there is D then 3 then 2 then 1. D is OD.
Old Mar 11, 2008 | 10:19 AM
deputyss's Avatar
u do if its stock
Old Mar 11, 2008 | 10:28 AM
CRAGER's Avatar
Administrator
Ever since 82' the f-body has had overdrive.
I can't remember which is which but the Camaro has D-3-2-1 and the Firebird has (D)-D-2-1, or visa-versa. Same tranny in both, just numbering on the console is different.
Peace,
Craig.
Old Mar 11, 2008 | 10:36 AM
AR15 guy's Avatar
I have seen some that don't show 1st gear. But you can still go down below 2 and it would be in first. Mine has (d) d 2 1.
Old Mar 11, 2008 | 11:32 AM
-98-Z28-Darkness-'s Avatar
my car has 123d setup
Old Mar 11, 2008 | 03:03 PM
WS6R6's Avatar
As far as I know, Camaro's show 12D(D) and Trans Am's show 123D. But both have the same tranny.
Old Mar 11, 2008 | 03:06 PM
5301113's Avatar
Your right.
Old Mar 11, 2008 | 04:02 PM
CRAGER's Avatar
Administrator
Your right.
...uh yea, I think that was already covered:
Peace,
Craig.
lol
Peace,
Craig.
Old Mar 11, 2008 | 04:11 PM
yeah i knew my was aftermarket for some reason since its 123d and not 12D[D] on my camaro
Old Mar 11, 2008 | 04:16 PM
CRAGER's Avatar
Administrator
Yours is NOT aftermarket. Look at the posts above ^ they state what you have exactly. And even if it were backwards it could be that the center console is from a Firebird. The ONLY "aftermarket" auto tranny used in our cars is either a TH350 (3 gears with no OD) or a Powerglide (2 gears again no OD).
Peace,
Craig.
Old Mar 11, 2008 | 07:07 PM
Peace,
Craig.
o sorry for not verifing what i mean i knew my center console was not stock....i thought it cam from and older camaro or a trans..was not sure
Old Mar 11, 2008 | 07:32 PM
The tranny shifts at 10mph then about 20mph is that typical? This is under normal driving load. Havent had a chance to watch it under heavy load.
Old Mar 13, 2008 | 12:43 PM
Rede's Avatar
If you're in doubt as to weather your trany is stock or not, the simplest way to figure out it you have o/d is to quite simpley count the number of times the car shifts.
Your rpms may tell the story too as long as they haven't been changed to anything supper low.
IE:
With my stock 3.23 gears 60mph would run around 1600-1700rpm.
With 3.73s, 60mph is more like 2100-ish.
But as I mentioned, gouing by rpms alone isn't very accurate.
