stall or nitrous???
Old May 25, 2008 | 11:14 AM
second_2_none's Avatar
Question stall or nitrous???
i've been saving up for stall converter for my car. i've been told that it can drop up to .7 in a quarter mile. but my buddie and i hooked his nitrous up w/ a 100 shot and took our cars on the highway. we both have similar mods except he is an m6 and im an a4. most of the time i will pull him a little till his 4th gear than he will start slowley walking on me. but w/his 100 shot he was gone. so now im starting to think about getting nitrous instead of a stall. im just wondering what some of you guys think would be the better buy. i drive the car mainly on the weekends and go to the track about once a month.
Old May 25, 2008 | 11:18 AM
bigpapi211's Avatar
stall
Old May 25, 2008 | 11:22 AM
my biggest thing about the stall is that i've heard it is a pain to drive around town. but i have never been in a stalled car before so i dont know how true that is.
Old May 25, 2008 | 11:31 AM
Websy21's Avatar
Not even close, I got the vig 3200 and can't even tell its there until I mash it. Got the car with it in there and if I had bought one myself it would be a vg 3600 at the smallest. Stalls are the best mod ever for a automatic, get one and you'll see why.
Old May 25, 2008 | 11:34 AM
jetlag's Avatar
I'm doing nitrous because I don't go to the track very much and rarely drive my car...It's cheaper and easier.
What mods are on your car? Our times and dyno numbers are pretty much the same...My car made 330/340, and 12.64
Old May 25, 2008 | 11:36 AM
squale iii's Avatar
nitrous is fun... get it on a momentary button and it'll make you wet your pants.
Old May 25, 2008 | 11:41 AM
jetlag's Avatar
Or get a window switch that senses TPS to turn on and be safe and not have to press a button
Old May 25, 2008 | 11:51 AM
JScamaro's Avatar
Both are very fun. Nitrous will be there when you need it and you'll be able to keep your gas mileage if its your daily driver.
Old May 25, 2008 | 01:08 PM
WheelmanWS6's Avatar
Since you have a bolt-on car, I would definitely recommend the stall, especially if you plan on spending more time at the track. The gains are pretty significant as u know, and if you plan on doing any motor work in the future, its a good supporting mod.
Old May 25, 2008 | 01:41 PM
i have a p&p maf & tb, lid, longtubes, o/r y, lm2, ls6 intake, and lca's. yeah i like nitrous cause like said before, its there when i want it. but i know you cant mess with a stalled out auto at the track. that and i've been told i cant get a cam w/out a stall.
Old May 25, 2008 | 03:48 PM
jetlag's Avatar
That was my problem....I don't want to have to do cam/stall/tune...I rarely race so nitrous would be a cheap and easy fix.... I really want to eventually go with a Procharger...so my reasoning is that nitrous will be easy to put on and remove when that time comes, and it's cheap enough to play around with for a little bit then sell it.
Old May 25, 2008 | 04:01 PM
qwk93ta's Avatar
go with a stall
Old May 25, 2008 | 05:26 PM
Reject's Avatar
nitrous, putting money on the 60e is pointless, once you start making real power it starts slipping gears or not going into gears at all, then you have to spend big money on GOOD built ones and even then it's a hit or miss deal, go nitrous a th400 tranny and a rear and your good to go till you blow your motor up
Old May 25, 2008 | 10:37 PM
71 chevy's Avatar
nitrous.!!
Old May 26, 2008 | 05:09 PM
Thrashed2's Avatar
You guys do drag race the money brackets right? How are you planning on being consistent with nitrous?
Old May 26, 2008 | 05:27 PM
Reject's Avatar
window switch, progressive controllers, **** iunno technology
Old May 26, 2008 | 05:35 PM
no i dont bracket, i just do heads up when i go to the track. wouldnt mind trying it sometime though. i have only had the car about 6-7 months so im still trying to dial it in and get a solid, consistant time.
Old May 26, 2008 | 08:26 PM
jetlag's Avatar
technology is stupid...i just have a nitrous button on my steering wheel.
Old May 26, 2008 | 09:20 PM
if i go with nitrous i will get a wot & window switch. well thanks for the opinions and advise guys! i will deff let you guys know which one i go with and how i like it.
Old May 26, 2008 | 09:26 PM
homerunhtr21's Avatar
I had a stall on my last DD and I probably wont get another one since it is my DD and it shot my gas mileage down to around 11mpg in town and with gas at $4 and no signs of lowering that just dont cut it. My tune might have been off although I was told by a few shops that it was dead on....It probably turned me away from stalled cars for a while unless I could be proved wrong :-/
