Burnouts
When I do a burnout, the rear of the car steps out left, is this normal??
If so, is there anything I can replace to keep it straight when smokin?
Also what damage could I do by doing burnouts, (Apart from pads / tyres), what might I break?
Thanks for your help,
Paul.
It slides because of the crown of the road. Mine slides to the right, but since you drive on the wrong side of the road, yours slides left.
To keep it under control, an upgrade of the rear's suspension is in order. Control arms, relocation brackets, torque arm, drag sway bar, pan hard bar will all work towards keeping the car straight.
When my car was stock, it took a lot of steering correction to keep the car straight during a clutch dump. Now after all that, I rarely think about the car going left anymore unless the roads are wet or some ricer left some puddle at the track. It can be quite the shock when due to water the car kicks out.
If when pulling away I release the brakes slow, I guess I'm putting less stress on the rear end?
It's abuse, it breaks parts. Until you put a semi indestrucatble rear in it, its the same rear that comes in an s10 pickup. DO they put a v8 into the s10 from the factory? Ever here of an s10 dropping the rear at the track? Not enough power thats why. The rear is weak and on the edge of being able to handle an oem ls1. Start throwing more power at it and abusing it and its on borrowed time IMO.
