Is it worth It
SC Lid w/Raptor Hood
Thunder Racing Custom Grind Split Pattern Camshaft
224/227 .563/.569 114 LSA
Comp Springs & Comp Titanium Retainers
Thunder Racing Push Rods
160 Thermostat
Nitrous Express Wet 125 Shot (also have 50-75-100-150 jets)
NX Twin Split Purge
NX LS1 Switches
Granatelli MAF
Flowmaster w/Cut Out
Harlan Shift Light /5800
NGK Plugs TR6
PRO 5.0 Shifter
HOTCHKIS Shock/Strut Tower Brace
HOTCHKIS Pan Hard Rod Adj.
HOTCHKIS Performance Sway Bars
IRS (Terminator Series) Lower Control Arms
INTRAX Springs
2000 C5 WHEELS
17x8.5 Front and 18x9.5 Rear
Kumho 712 255/40 ZR17 FRONT AND 275/35 ZR18 REAR
I have seen several pictures of the car and it looks like it has been well taken care of. The owner is asking 15,900 for this car, do you guys think that I should buy this car. The only thing that I am worried about is that the car has nitrous, I talked to the owner, and he said he has only used it once, and that was on the dyno. And the dyno numbers are 421 RWHP, and 524 RWT, before the cam was installed. Do you guys think that the nitrous has given the engine any problems, and is that nitrous kit fairly safe. I would really appreciate some imput, it would help alot.
. Why would anyone spend the money on nitrous and then never use it? I hope he didn't try to tell you it was his grandma's car as well. The truth is when you buy a car with a lot of go fast mods, you might as well assume the guy used them. With a car that's modded that much, who knows how it was treated. I'd say buying that car would be a catch 22 and you better have some extra cash on hand to fix things he may have broken or worn out with hard driving. I have a hard time beliving the story about the nitrous only being used once.
Will you have extra money on hand to fix stuff if it breaks?
I'd favor a stock untouched car personally.
Seems like that car should have headers on it with the listed mod's...
Is the inspection current on the car?
Friend of mine bought a car that wasn't current on inspection and it turned out the car couldn't pass the sniffer test.
PASS
Find a good NA car that you can build on and you will be much happier....unless you can talk him down to 10000...then that 6 grand can be used if there is a problem....so you can rebuild. besides...you're young...live at home for a while...save up money...do real mods on a NA car....do the spray or blow it later....besides...if you beast it out first...the other stuff acts way better.(but you do have to plan a little more for it.
and for the record I live in the Overland Park area....and Mix 4-6 night a week at THE HURRICANE. and work for a few major sound companies...so I work a lot of Pro Level Music...I got season Ticket to royals...so you might have seen my car there(if you park in lot M)
soundengineer I'm I the Overland Park area to. I have probably seen you driving around, thats why I have seen that plate before.
