z28 and SS
No difference in acceleration if you are comparing both vehicles with the same transmission or gearing (ie. 3.23 auto vs 3.23 auto or 6spd vs 6spd) The SS has stiffer suspension. It's like comparing the Firebird Formula to the Trans am. The better driver is going to win. If you want to get technical the base LS1 models (Formula, Z28) actually weigh slighlty less. Less weight is always good at the track... if you can hook.
Just my .02
With the same options, how would a Z28 weigh less than a SS? SS has a fiberglass hood and spoiler, unless the extra inch of wheel adds that much weight.
I'll be the first to admit that I don't know quite as much about the SS as I do about the WS6. That being said, wouldn't comparing a Z28 and a Z28 SS be more like comparing a Formula or Trans Am to a Formula WS6 or Trans Am WS6? We are talking about comparing a standard 305hp car to a 320hp car with minor suspension tweaks. I'm not saying there is a huge performance difference in the 2 vehicles, but there is a difference.
Just my .02
Just my .02
alright, another person who thinks WS6's are faster, i refer you to the sticky in the first section of this forum, a ls1 is a ls1 is a ls1, WS6 doesnt unlock a secret horsepower code, 305 vs 320 is what we intelligent people call a marketing ploy to sell vehicles by making uninformed people believe they are getting a faster car, WS6 means minor suspension upgrades, ramair hood (which isnt true due to a baffle), and some nicer wheels, now onto the op's statement, without SLP performance mods an SS is same as Z28 in performance, SS just means hood, spoiler, and wheels
I'm not sure which sticky you are referring to that says that a WS6 has the same hp as a stock TA (or that they run the same times at the track). Link?
also heres the link to year changes https://ls1tech.com/forums/showpost....80&postcount=2 those are the only differences your really going to find. as for a thread that says ws6 and trans am have the same horsepower, go through the first or second page of recent posts on here and im sure there will be 8 threads just like this one. this question has been beat to death!
If you have the option to pick up an SS over a standard Z28, go for it. They do look much better with the wheels, hood and wing. Performance is nearly identical. They are also easier to resell than a standard Z.
I understand that an LS1 (the core engine itself) is an LS1 is an LS1, but to say that adding wider tires, a lower restriction exhaust and a more tuned suspension nets you ZERO... I just have a hard time getting behind that train of thought. One of my best friends has a non-SS A4 Z28 and he has not yet beat me or even kept up 100% when we've run the 2. I'm not here to start any arguments so I'll just bow out and say I was wrong about any differences in the 2 base vehicles...
exhaust options were only on the SLP cars i.e. SS and Firehawk, the WS6 has the same exhaust as the t/a just with different tips, you arent gonna find that on a thread, its called looking at the part numbers on the muffler when you take them off, they are the same, WS6 was built by ASC and has no performance upgrades from SLP, wider tires do not make more horsepower, yes a WS6 and SS are faster in 1/4 miles due to the hood adding air, if you dyno a WS6, a t/a, and a formula you will not see a 15 hp difference in the cars, more like 2-3 depending on age and wear on the motors, the only reason they are faster is when you are going at a high enough rate of speed for the hoods to actually work, i repeat WS6 is not SLP, has no SLP performance upgrades, the WS6 exhaust is not a secret 15hp adder, quit thinking you are the god of cars cause yours says WS6, its not that special, very nice cars dont get me wrong i like them, but they arent superman over the other LS1's
No, they usually make better traction.
You're right, the hp difference comes in at higher speeds. I don't know too many people that are into "dyno racing". If you go back and re-read my initial post, my point was that there is a slight performance difference between the bone stock "Ram Air" models and the bone stock "non Ram Air" models; not much, but it is there. You were the one that said "an SS is same as Z28 in performance".
Thanks, I needed you to explain that to me.
Whoa, where the hell did that come from? Napoleon complex much? Seriously, when have I EVER said anything about a WS6 even being special much less "superman over the other LS1's"?
Wow alot of misinformation here.
SS = fancy hood, fancy spoiler, wheels and badges.... Now you can get an SS and have slp options on it, intake, exhaust, suspension but those are optional not every SS came with them. Performance wise a Z28 and a base non slp optioned SS are identical from ls1 to exhaust tip. Also the ls1 was underrated as to not compete with the vette. GM says the z28 makes 310 (2002) the SS makes 325 and the 04 GTO makes 350hp in reality they all make around 345 - 350hp same as the vette of those years. Now the 01 and 02 and later ls1 did have the ls6 intake manifold that would net it around 5 more hp.
http://media.gm.com/division/canada/...999Camaro.html
According to GM, the "base" SS package consists of:
"SS" Performance and
Appearance Package: Includes
320-hp, forced air system,
275/40ZR17 Goodyear Eagle F1
speed-rated tires, 17"
aluminum wheels, enhanced
spoiler, specific low-
restriction dual exhaust
system, power steering
cooler, high performance
ride and handling package,
"SS" badging and 3.42 axle
ratio with 6-speed manual or
3.23 axle ratio with 4-speed
automatic transmission (not
available with Sport
Appearance package)
So are you saying there was a way to get ONLY the hood, spoiler, wheels and badges without getting any of the "performance" upgrades?
Also, just for the record:
I went outside and climbed under my WS6 to get the muffler numbers to see if you were indeed correct (since that would mean that GM had left themselves wide open for a false advertising lawsuit). I went on GMPartsDirect and looked up the stock f-body mufflers and they DO show different mufflers (and part #) for those equipped with the "Performance Pkg" (WS6).
http://www.trademotion.com/partlocat...layCatalogid=0
