Torsion Bar issues
Hi, I am looking to buy a 98 Ta that i found and the owner says that the only issues it has are that it needs a rear bushing kit because the torsion bar gives a little thump when you get on it. Is this common with these cars as they get older? Does this sound Kosher or should I be looking at anything else which may go along with this issue? I have always wanted an LS1 car and this is as cheap as i am gonna find one close to where i live, but i won't have a lot of cash to dump into it after buying it so i don't want to buy a headache right off the bat. The Carfax checks out clean so if this issue is minor then i will go for it. Any advice here would be appreciated.
Thanks
F Small
Thanks
F Small
pretty common problem with cars of age...test drive it for yourself and listen to the noise and see if it seems like a suspension problem...otherwise sounds like you did your research and congratulations!
mines loosened up twice and it does that whenever you put load on it or comes to a stop. i keep tightening the bolts back up but i think the rubber mount is broken or torn because it keeps coming loose. worst case senario, you could get a tunnel mounted torque arm which i plan on doing eventually anyway
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
