Ok to use this style jackstand on the front subframe rails?
Just curious if it is safe to put a jackstand of this style under the front subframe rails even tho the rails are wider than the stand pad or w/e its called. ![](http://www.redhummer.com/myhummer/tools/91497010.jpg)
just wouldnt want the stands to slip.
yup I always do that lol and not only that but i keep 2 jacks under the car just below the kmember and one just below the diff housing as well as an extra set of jackstands in case that fails lol. I'm too paranoid lol
Location: Your girl's back door giving her the long stroke while you're at work
check out the link below, click on install documents on the left, then scroll down to the Miscellaneous section. Look for the one that says "LS1 lift points"
http://www.installuniversity.com/ins...sity/index.htm
