Catch Can????
Old Sep 16, 2008 | 04:37 PM
1FASTBIRD's Avatar
Originally Posted by dutinsss
i'm working on it, but nobody wanna gimme no muhney
Just kepp prawling
Old Sep 16, 2008 | 04:43 PM
dutinsss's Avatar
will do
Old Sep 16, 2008 | 04:48 PM
gymratt's Avatar
I wouldn't do the ls6 pcv conversion, not worth the money. Just get a good catch can like the rev extreme version, it's about 80bux-ish. Helps to reduce the chance of detonation too from recirculated crankcase vapors and oil entering your intake manifold. AMW cc are great too, but don't think they make em anymore
Old Sep 16, 2008 | 05:21 PM
1FASTBIRD's Avatar
Thanks for the help too bud
Old Sep 16, 2008 | 07:30 PM
Justin93's Avatar
the best way to do it would be to get an ls6 pcv conversion kit from thunder racing. if you go to ls1howto.com it shows how to install it and how it works. for the money, just a catch can is a good way to go it's just the ls6 pcv conversion is probably the BEST way, if you know what i mean.
I did both. It looks much better without the ls1 pcv hoses in there and was very easy to do! FYI all you need is the ls6 valley cover which only costs 69.99 from PACE performance. Thunder racing gives you the hose as well but that is not needed if you are going to do a catch can too!
Here is the system I copied exactly!
http://www.ls1.com/forums/showthread.php?t=81389
Old Sep 16, 2008 | 08:23 PM
1FASTBIRD's Avatar
Thanks for the link and the help
Old Sep 16, 2008 | 08:40 PM
dutinsss's Avatar
so you didn't use a pcv valve? i was going to do that exact setup too but wondered why he didn't use a pcv valve.
Old Sep 17, 2008 | 10:35 PM
Justin93's Avatar
Its attached on the bottom of the LS6 valley cover.
