Theft Deterent Module
Old Sep 24, 2008 | 10:22 PM
nightmare23's Avatar
Default Theft Deterent Module
where is it located exactly..im trying to do a secuirity bypass..thanks in advance..pic would help
Old Sep 24, 2008 | 10:44 PM
SOM02WS6's Avatar
It is usually on the right side sitting on top of the Right rear fender. Take the panel off that you use to access the spare tire and look around. Little black box with a *** on it.....
Old Sep 24, 2008 | 10:47 PM
o ok ..kool thanks ...
Old Sep 24, 2008 | 11:03 PM
damn its not there
Old Sep 24, 2008 | 11:24 PM
pls guys ..i need to do it by the morning
Old Sep 24, 2008 | 11:45 PM
ttt.........
Old Sep 25, 2008 | 06:59 AM
Old Sep 25, 2008 | 07:52 AM
FirebirdFlyboy's Avatar
That's where mine is. It's not down in the well where the tire is. It's up on the hump near the speaker.
Old Sep 25, 2008 | 07:56 AM
smcnealy's Avatar
What part of the security are you trying to bypass?
If it's just the key's "chip" you're looking for a connector under the steering wheel. Other than that, the BCM (body control module) is right behind the glove compartment.
The guys above are telling you where the shock sensor is. Not all are equipped with the shock sensor.
Old Sep 25, 2008 | 10:30 AM
samson_420's Avatar
Yup, that is true.
Our shock sensor is not worth a crap anyway really. You car could be in a earth quake and it will not go off.
But to bypass the system, you would just bypass the VATS. The BCM does a lot more than just the alarm part.
Old Sep 25, 2008 | 11:52 AM
BriancWS6's Avatar
How would you go about disabling the VATS? My buddies car automatically arms the alarm within a few mins of shutting the door. Then, every time you open the door the damn alarm sounds unless you hit the unlock button first. It's annoying as hell!
Old Sep 25, 2008 | 12:35 PM
smcnealy's Avatar
Brian, that's not VATS that's sounding the alarm. The car's manual should tell you how to not arm the alarm. There's a way to get into programming mode (pull radio fuse turn key on and off 3x in 5 sec). From there a bunch buttons can change BCM settings. But that's all in the owner's manual and I don't remember off the top of my head anyway.
VATS is the "chip" in GM keys. Disables your fuel injectors unless you're using the correct ignition key.
Last edited by smcnealy; Sep 25, 2008 at 12:39 PM. Reason: might as well say which fuse
Old Sep 25, 2008 | 12:36 PM
samson_420's Avatar
I just bypassed the VATS in the column. It never sets itself. It would suck if it did.
Old Sep 25, 2008 | 01:59 PM
Ryanm86's Avatar
Originally Posted by samson_420
Yup, that is true.
I disagree if someone farts too close to my car it sounds a warning, you just have to adjust the shock sensor.
Old Sep 25, 2008 | 03:39 PM
406malibu's Avatar
haha yea same here, if a harley goes by it will go off, if it isnt sensitive enough, just reach in there ant turn the ****
Old Sep 25, 2008 | 06:55 PM
BriancWS6's Avatar
Thanks, I don't think he has his owners manual, but I have mine so next time we have some time we'll mess with his car and see what happens.
Old Sep 25, 2008 | 07:08 PM
so its the one below the steerin wheel slightly to the left with alot of wires ?
damn does anyone know how to do it?? im looking at online instructions but all for other vehicles my car doesnt start ...just the security light blinks
Old Sep 25, 2008 | 07:30 PM
ttt.........
Old Sep 25, 2008 | 07:33 PM
smcnealy's Avatar
Here's a good site on VATS/PassKey: http://sethirdgen.org/vats.htm .
And the key numbers are here: http://www.thirdgen.org/vats_passkey_system .
Security flashing means you don't have the correct resistance in your VATS bypass you made. You won't be able to try again for 4 minutes.
Old Sep 25, 2008 | 07:40 PM
ive tried it for 4-5 days ....what fuses should i check?? damn im all newbee i dont understand wat half those things are
