Should I bore out my 346ci ?
I was wondering if i should bore out the 346ci int my 04 GTO. Does anyone know if I could bore it to 383ci or 402ci on a stock block? And how much would it cost me?
The LS1 stock bore is 3.899" and can be bored to 3.905", anything more will need to be resleeved. The stroke is only 3.622", but you can add a 4.00" crank and make a 383 (when bored). There are other length cranks, like a 3.90 or so. You can't make a 402 as you would need a 6.0L block for that. It has a 4.00" bore, and adding a 4.00" stroke will yeild a 402.
http://www.wallaceracing.com/cid.php
Eidt: you must have mistyped the bore and stroke as 3.95" for the bore and 3.62" for the stroke. Then I get 354.8 as well.
383's can be potent, it's a simple build.
A 402 is simple as well, I would spend the extra money to get an Iron Block, cause you will have to get a Crank, Rods, and Pistons for a 383, so might as well get the 4" Pistons and the Block. That and your Acessories and Cover Plates will bolt right up.
texas-speed sells complete 383 short blocks for $3600 you could also get the 6.0 truck motor and make a 408. A 383 rotating assy from eagle is about $1600 and get your block machined and assembled. I would say prolly right around $4,000. Or just get a shortblock for $3600. Powerwise, depends what you do, from 450hp & up. Talk to Texas speed and shops of that nature!!
Also, its more than just "boring" to make it a 383. Takes new Crank and pistons, plus the block work.
You can buy the 402 crank and pistons and a 6.0 block for damn near the same price.
The engine has to come out of the car anyway, so why not do the larger, stronger motor?
