To worry or not to worry...that is the question..
Have 5 DTC's
-P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
-P0410 Secondary Air Injection System Malfunction
-P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
-P0418 Secondary Air Injection System Relay ‘A" Circuit Malfunction
-P1416 Secondary Air Injection (AIR) System Bank 2
My car smells like its running really rich and doesnt feel like its pulling as hard. How do i fix these things so it will stop pulling these codes?!?!?
It's a air pump that blows fresh air to the exhaust manifold. Take the screws out of the black plastic thats in between your driver side wheel and front bumper you'll see a pump and all the plumbing going into the engine compartment. Also check you fuses. If you dont need emmissions this would be a great excuse... I mean great time to add some headers and a ORY.
The first issue you need to adress is your Oxgen sensor! Bank 2 sensor 1 is passanger side front 02 sensor. Fixing this will make your car run better. Your A/F is all over the place when your front 02 is not reading correctly.
I used the Bosch 1311's the first time mine went bad. The only problem with them was they seemed to burn out and throw the same code every 6-8 months. After switching back to the factory AC Delco sensors the code has stayed off.
