Texas Speed Prototype 2010 Camaro SS Induction
We recently finished testing 5 different versions of the TSP 2010 Camaro SS air intake kit. We've finally decided on a version that worked the best overall on the several cars we've tested it on. This kit will feature everything you need to do a complete install on your SS in your driveway. The combo has been dyno tested with several different modification combos.
Here's a copy of a couple of the dyno sheets & a image of the prototype. Keep in mind it will have some changes & look a lot nicer when it's a final version, this is just a basic proof-of-concept prototype. The final version will include several changes such as trim for the heat deflector, full ceramic coating, just to name a few...
Pricing is available on our website & the first run of intakes will be ready in less than 2 weeks!!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
