BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004)
LS1Tech Premium Sponsor
BMR Fabrication
Driveshaft Tunnel Brace for the 2010 Camaro
Strengthen the floor pan and drive shaft tunnel in your 5th Gen Camaro with a Driveshaft Tunnel Brace from BMR Fabrication. Constructed from 1” x 2” x .083 wall rectangular steel and 3/16” CNC laser cut steel plates, these braces replace the factory stamped steel design. The BMR Driveshaft Tunnel Brace (DTB004) uses factory mounting holes while increasing the rigidity of the tunnel in the critical area where the driveshaft carrier bearing is located. When used with the BMR Sub Frame Connectors, the Driveshaft Tunnel Brace ties the driver side and the passenger side together into a sturdy cross-brace. Installation time is less than 1 hour. Available in black hammertone or red powdercoat finishes.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com, email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
