New Products Showcase Come inside to see the newest hardware!
Lingenfelter C6 ZR1 Supercharger Cast Aluminum Air Intake New Pictures
Old 12-21-2009, 01:50 PM
Jeff@LPE's Avatar
Default Lingenfelter C6 ZR1 Supercharger Cast Aluminum Air Intake New Pictures
Here are some pictures of the casting before we install the bearings and shaft assembly. We expect to have them assembled and ready to sell mid January 2010. Lingenfelter has seen chassis dyno tests results of 30 horsepower rear wheel gain over the stock snout on a ZR1 in back to back testing with our upper pulley kit already installed.. The LPE version is on the right side of each picture.
Here is a picture of the assembled supercharger air intake snout with a 10 bolt hub that will allow the easy changing between our 2.35 or 2.6 diameter pulley.
L250110309 High Flow LS9 supercharger snout or front cover with pulley hub $1,495.00
L220136109 2.35 11 rib LS9 10 bolt pulley $129.95
L220146109 2.6 11 rib LS9 10 bolt pulley $129.95
For customers that want to use the stock snout we also will offer a 10 bolt hub so you can use the 2.35 or 2.6 diameter pulley
L220126109 LS9 10 bolt supercharger pulley hub, stainless $59.95
Old 02-08-2010, 02:25 PM
Jeff@LPE's Avatar
New front covers are in!
Quick Reply: Lingenfelter C6 ZR1 Supercharger Cast Aluminum Air Intake New Pictures
