MSD LS Atomic 2950 for LS2/LS3 In Stock at SK Speed!
http://www.skspeed.com/ProductDetail...ductID=M462950
Install Instructions:
Whats up everyone, we just got some of the new MSD Atomic EFI kits in stock for LS2/LS3 engines. Im still waiting to get the conversion kits in stock for the LS1/LS6 as well as the truck adapters.
MSD is making Atomic EFI the simple solution for your LS EFI needs. Start your installation by knowing that you’re getting everything you need for your crate engine. These kits are each designed for a specific engine and are supplied with the Rail Assemblies, Handheld Controller, Power Module and Harness, Wide-Band 02 Sensor and Bung, -6 fittings for the fuel rails and hose for the cross-over.
MSD's Atomic LS system not only will make your LS engine perform better, this system provides the easiest installation possible with less wiring, resulting in a clean engine compartment. The Atomic LS EF system does not require an external computer. You simply answer a few questions on the supplied handheld controller and the engine will fire right up. Once your engine is running, you will be able to dial-in advanced settings such as air/fuel ratio targets, ignition timing, and much more to customize the Atomic to your engine and driving habits. The Atomic will learn how to best tune your LS engine so you can enjoy the performance and drive ability of your engine. MSD has a variety of advanced programming features that are simple to navigate through the handheld programmer. These unique features allow you to really tune your LS engine . Additional benefits and features include the following:
* Accepts forced induction
* Nitrous input for spark retard and nitrous A/F targets
* Program different temperatures to activate two cooling fans
* Advance or retard the ignition timing up to ten degrees over the factory setting
* Select a rev limit through fuel and or ignition cut off
* Compatible with OE variable cam timing control
* Compatible with return or returnless fuel systems
* Supports up to 1000 horsepower
* Accepts mechanical and electronic throttle control systems
* Recognizes 24 or 58 tooth crank trigger wheels automatically
Retail is $2495 - PM me though if interested
