Quik-Latch Push Button Hood Pin/Universal Fasteners
A hot new line we just started stocking at SK Speed.
http://www.skspeed.com/SearchResults...rID=Quik-Latch
![](http://i77.photobucket.com/albums/j58/skspeed/QuikLatch_zps10fdaf15.jpg)
Tired of the traditional style of hood pins that rust, or lanyards that scratch the paint? Have you lost your hood pins due to removing the lanyard in hopes of protecting the paint finish?
Quick Latch products has developed a new generation of hood fastening technology that far surpasses traditional hood pins in both style and functionality. Automotive enthusiasts often experience problems with losing hood pins, or even forgetting to reinstall them, with rust, and also with lanyards that scratch expensive paint jobs.
Quik latch hood fasteners solve these problems with a sleek, and simple yet elegant snap shut and quick release action. Quik Latch hood fasteners mount to the hood, and line up with studs placed on the core support, or other bracket. Once the hood is closed, Quik Latch fasteners automatically latch to the studs mounted on the core support, and will not release the hood until the center button on the top of the mechanism is depressed. Quik Latch products will not rust, can be painted to match your car, and are manufactured in the United States. Customers who utilize Quik Latch hood fasteners can rest assured knowing that they are adding style, function, and exclusivity to their custom cars. Any reputable custom auto shop should be able to install Quik Latch products for you, or you can choose to self-install.
The Quik-Latch Mini Latches have recently been approved for use in competition by the NHRA! Check out the letter below sent to Quik-Latch by NHRA technical services. The Quik-Latch mini latches are highly effective removable fasteners for body panels, hoods, trunks, and interior compartments. The amount of potential applications for the Quik-Latch mini is only limited to the imagination of the installer.
The Air Cleaner kit is available in Satin, Polished and Black. It comes with a 1/4-20" Stud and allows the quick release of the Air Cleaner Lid $27.99-$29.99
![](http://www.skspeed.com/images-dyn/ProductImages/Thumb/QLAQL25AC.jpg)
![](http://www.quik-latch.com/images/MiniLatchAirCleaner5.jpg)
The Quik-Latch mini latches are of the same basic design as the larger hood pin sets, but scaled down and significantly cheaper. In addition with the ability to function as automotive fasteners, the Mini Latches have multiple applications for which they could be utilized, even outside the realm of automotive customization. That is the real advantage of the Quik-Latch mini - its versatility. Our customers have used them on street rods, dedicated drag race cars, cabinets, custom enclosures, remote control model airplanes, and go carts, to name a few. There are probably customers out there who have found applications that we don't even know about yet. If you have something that needs to open and close repeatedly that also needs to be securely latched, a Quik-Latch mini could most likely be adapted.
The Quik-Latch mini latch is a push button latch roughly larger in diameter than a quarter. It is incredibly strong for its size as well, as it can withstand a pulling force of 150 pounds before experiencing failure. The latches have been approved by the NHRA for use in drag racing competition, which lends credibility for how strong and durable the latches are.
The Quik-Latch mini latches are made of T-6 aluminum and stainless steel, which resists corrosion. They can also be painted or powder coated if a customer so desires. Last, but not least, the latches are manufactured to the highest of standards in the United States. Also available in Black, Satin or Polished.
![](http://www.quik-latch.com/images/MiniMini1.jpg)
As for the Full Size Hood Pins, 3 Styles are available.
Low Profile: $249.99 Satin - $299.99 Black - $299.99 Polished
![](http://www.quik-latch.com/images/Low_Profile.jpg)
2.50 Inches Upper Latch Mechanism Diameter
2.20 Inches Lock Ring Diameter
1.15 Inches Latch Mechanism Height
2.88 Inches Mounting Stud Length
![](http://www.quik-latch.com/images/DodgeCharger.jpg)
![](http://www.quik-latch.com/images/DodgeCharger4.jpg)
![](http://www.quik-latch.com/images/Malibu4.jpg)
GT Style Available in Polished - $299.99
![](http://www.quik-latch.com/images/GT.jpg)
1.90 Inches Latch Mechanism Height
![](http://www.quik-latch.com/images/S197G.jpg)
Twist Lock- Available in Polished $299.99 - Black $299.99
![](http://www.quik-latch.com/images/Twist_Lock.jpg)
3.00 Inches Upper Latch Mechanism Diameter
![](http://www.quik-latch.com/images/OldMustang3.jpg)
LS1Tech Sponsor
Very Nice!
__________________
Don't forget to check out our products at www.saccitycorvette.com
![](https://ls1tech.com/forums/signaturepics/sigpic197936_1.gif)
If you like our products, tell others! If not, tell us!
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
