UMI Peformance New Product- Drag Anti-Roll Bar for the 64-72 GM A-Body
UMI Performance, Inc.
Drag Anti-Roll Bar for the 1964-1972 GM A-Body
P/N 4045 priced at $479.99
UMI Performance, Inc. is pleased to announce the availability of our new Drag Anti-Roll rear sway bar for 1964-1972 GM A-body applications. This 1-3/8” dia hollow sway bar is axle tube mounted using our tried and true CNC machined serrated tooth mounting clamps, aluminum bushing mounts and heavy duty u-bolts. Strong double shear mounts and four high grade 3/8” fasteners attach the race quality rod ends to the chassis. Three position adjustability delivers enough roll resistance to tame your 11 second drag radial car or your 8 second full slick strip missile. The UMI manufactured hex adjusters ensure a perfect fit and provide preload capability to straighten your launch. The P/N 4045 drag bar has been designed to accommodate the factory rear housing, 12-bolt, Ford 9” and Moser M9 while still offering great ground clearance and a clean look (available for 2.75”, 3.00” and 3.25” rear axle tubes). These bars are available with tough red or black powder coat and are designed and manufactured with pride in Philipsburg, PA.
www.umiperformance.com or 814.343.6315
