Fuel Pump Upgrade Harness and In-tank Harness for Walbro E85 Pump
By popular demand we are now offering in-tank harnesses for Walbro's F90000267 E-85 430LPH fuel pump for use in Delphi SUV fuel modules.
ITWH-029 for Delphi modules up to 2003
![](http://racetronix.com/product/ITWH-029/ITWH-029-XL.jpg)
ITWH-028 for Delphi modules 2004 and up
![](http://racetronix.com/product/ITWH-028/ITWH-028-XL.jpg)
Most modules up to 2003 have the older style MP150-type bulkhead connector shown here:
![](http://www.racetronix.biz/mmWEBSTORE/Images/12176895.jpg)
These bulkhead connectors are prone to failure hence Delphi's change to the newer MP280-type connector. If you have an early model factory original module you MUST upgrade your bulkhead connector to our RCS-028 shown here since the factory MP150-type is maxed out at 14 amps:
![](http://www.racetronix.biz/mmWEBSTORE/Images/153166027a.jpg)
Pre-2004 SUVs will use a combination of these three items to complete the wiring upgrade*:
FPWH-017 Fuel Pump Harness MP150S-4M > GT280S-4F
RCS-028 Connector, Fuel Bulkhead 4-Way 280/150
ITWH-029 In-tank Harness, MP150/280 4W> DCSS E85
* If the Delphi module has been serviced/replaced the chassis connector may have been changed/spliced using a MP280-type connector. In this case our FPWH-017 harness will not be compatible since the input uses the MP150-type square connector. In this case our FPAH-001 150 to 280 Fuel Pump Adapter Harness may be used to adapt the input. The FPWH-022 is connector compatible with this upgraded configuration but the wire positions are not.
2004+ SUVs will use a combination of these two items to complete the wiring:
FPWH-022 GM SUV/Car 280 Fuel Pump Wiring Harness
ITWH-028 In-tank Harness, MP150/280 4W> DCSS E85
We offer the Walbro F90000267 fuel pump along with other installation hardware such as filter socks (11m inlet), fuel tubes, crimp clamps (12.3 or 12.8mm for pump), etc.
www.racetronix.com
www.racetronix.com
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3576_1.gif)
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
