UMI Releases New Product- Roto-Joint Rear End Housing Bushings for 65-88 GM A/G-Body
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
Roto-Joint Rear End Housing Bushings for the 65-88 GM A/G-Body
P/N 2999 priced at $129.99/set
UMI Performance, Inc is proud to introduce our P/N 2999 GM A/G body axle housing Roto-joint. The 2999 allows full articulation of the GM 4-link rear suspension. By using 2999 and either Roto-Joints or rod ends in the other six locations, your 4-link will move bind-free. Whether it be autocross transition, road race cornering or just back road corner carving UMI has you covered. For street use, they also pair well with our hybrid poly/Roto combination arms - poly for comfort and Roto-Joint for performance. These Roto-Joints install with a gentle press fit and are retained by an easy to install spiral retaining ring. The 6061-T6 aluminum housing is pre-greased with Synco Super Lube and will provide smooth motion for years to come. 100% manufactured in Philipsburg, PA-USA.
>Website Link Here<
![](http://umiperformance.com/catalog/images/large/2999a_LRG.jpg)
