Cbm 250/175amp high output billet ls alternators
CBM MOTORSPORTS
250/175AMP HIGH OUTPUT BILLET LS ALTERNATORS
![](http://custombuiltmotors.com/images/170%20gm%20%20side%20front_back.jpg)
6 phase CBM Motorsports alternators are designed for LS style engine applications, they offer more low RPM output, and a lower turn on RPM than any other performance alternator on the market, period. These units feature cutting edge 6 phase hairpin stator technology for incredible durability and high RPM stability. Instead of a single rectifier assembly, these units feature TWIN rectifiers and twice as many diodes to spread out the heat, and dramatically increase durability. These units are 15% more efficient than other alternators, so less horsepower is wasted in the form of heat than other popular brand alternators. If you have poor alternator charging performance at engine idle speeds, low voltage, or pre-mature alternator failure due to RPM or heat, a CBM high amp alternator is the solution. “one wire” CBM units require no engine revving for charging to begin, simply start the engine and the alternator will do the rest. Choose between a GM or Toyota regulator and a side or rear output stud location. These units are Made In The USA and also feature:
CBM TECH. 909.291.7550 ext.2004
SKU: CBM-250-GM-S-ALT
Sign up for CBM newsletter.
![](http://www.custombuiltmotors.com/images/facebook_logo.png)
- Oversized charge post for sturdy cable connections.
- Premium low-drag bearings.
- Ultra-precision balanced rotor for 20,000 rpm capability.
- Twin rectifiers with 12 press fit diodes.
- Hairpin epoxy re-enforced vibration resistant stator.
- Precision black anodized billet pulley.
- 1 year performance guarantee.
- Integrated ground cable.
- CBM logo.
- Machined finish.
![](http://www.custombuiltmotors.com/images/35-Mind-Numbing-YouTube-Facts-Figures-and-Statistics-Infographic19.png)
