New Products Showcase Come inside to see the newest hardware!
LS Swap harness now from $575 from Painless Performance, including a free ECM flash!
Old 01-20-2015, 04:49 PM
dlove's Avatar
Default LS Swap harness now from $575 from Painless Performance, including a free ECM flash!
To bring in the new year, we're happy to announce all new pricing on our line of fuel injection harnesses! Something that rarely happens in the aftermarket world.
With the addition of some new machines at our facility, we were able to bring the cost down significantly on the most common two harnesses the LS1 and the truck harness. These harnesses still maintain all of the same great benefits and features as before.
Here are some of those features:
TXL Wire
Only the highest quality multi-strand thermal cross-linked (TXL) wire is used. (Lightest and thinnest insulation you can get)
Attachment 723996
Fuel Injection Test Board
After each fuel injection harness is built we then test ALL of them on the corresponding test board. Test boards check continuity, pin out and conductance (crimp quality). If you have purchased a Painless fuel injection harness, rest assured it has been thoroughly tested before it was sent out.
Attachment 723997
Tech Samples to assist with calls
If you need some help trouble shooting an installation, Painless has a great team of experienced technicians on board to walk you through any issue. Every step of the way, our goal is to make it easy, simple and painless.
Attachment 723998
TEXAS
Attachment 723999
Reflash Program for GM's LS Engines
All customers who purchase a Painless EFI harness for LS engines are eligible for a free reflash of the ECM, saving potentially hundreds of dollars. With this it makes our harness the most bang for the buck harness for someone who needs a stock swap tune.
Attachment 724000
Here's a few more:
- Lifetime warranty!
- Built in check engine light
- Regularly in stock from many vendors including Scoggin, Summit, Jegs, Amazon, etc.
Thanks for looking!
Check out the LS1 harness here
Check out the truck version here
Quick Reply: LS Swap harness now from $575 from Painless Performance, including a free ECM flash!
