New Products Showcase Come inside to see the newest hardware!
SacCtyCorvette's Latest! Precision Billet Barbell/Oil Diverter
Old 02-22-2017, 06:22 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default SacCtyCorvette's Latest! Precision Billet Barbell/Oil Diverter
SacCityCorvette's
Precision LS Billet Barbell and other Oil System Improvement products!
The Oil Galley Barbell in your LS based engine is something that is over looked. And yet it serves a very important mission of directing oil to the oil filter. If oil leaks past the Barbell it will go unfiltered directly to the Cam Bearing, Lifters, Crank and Rod Bearings. (See Diagram Below) The factory Barbell is approximately .020” to loose so particles as big as 500 Microns can leak past the factory Barbell. Your oil filter will filter out 15 to 25 Microns depend on the brand of filter. Our 7075 Aluminum Precision Billet Barbell fits with approximately .001” clearance which will let only about 20-25 Microns pass by, that same as the filter.
Another important part is the shaft of the Barbell. The oil has to flow around it to get though the oil port. Our Billet Barbell has a 30% smaller shaft for much less flow restriction.
We have also added a 1/4-20 threaded hole in the end of our Barbell for easy removal. Just screw a 1/4-20 bolt in and pull the barbell out. No more digging and prying to get the factory one out.
Better engine protection from much less and smaller particles bypassing, smaller less restrictive shaft for better oil flow, replaceable High Temperature Viton O ring and for ease of service a threaded 1/4-20 hole.
Why would you ever put the plastic factory Barbell back in your expensive LS engine build?
See Our other Oil System Performance Improvement Products below.
Fits LS1-2-3-6-7-9-LQ4-LQ9-4.8L-5.3L-6.0L-6.2La and more! Also available for the new LT1/LT5
Only $26.95 Free Shipping
http://www.saccitycorvette.com/Billet-BarBell.html
Here you can see how the unfiltered oil gets by the loose factory Barbell. Also you can see how our Barbells smaller shaft will improve oil flow!
Check Out all 4 of our Oil System Improvement products!
If you don't know much about how the Barbell works check out video.
Video of how loose the factory Barbell really is compared to our billet Barbell.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 04-28-2017, 01:59 PM
LS1Tech Sponsor
Our Billet Barbell oil diverters are now available for the new LT1 &LT4!
http://www.saccitycorvette.com/Billet-BarBell-LT1.html
__________________
Old 11-18-2017, 02:01 AM
LS1Tech Sponsor
Keeps unfiltered oil out of your engines bearing and lifters!
__________________
Old 01-20-2018, 10:51 PM
LS1Tech Sponsor
We have the the Billet oil system improvement parts in stock when you need them.
__________________
Quick Reply: SacCtyCorvette's Latest! Precision Billet Barbell/Oil Diverter
