MM340 Poly LS Motor Mounts
FOR IMMEDIATE RELEASE
1993-2002 F-Body Polyurethane Motor Mounts
MM340 - $119.95
Reduce engine movement and improve throttle response on your LS equipped 1993-2002
F-Body with Polyurethane Motor Mounts from BMR Suspension. The factory mounts are designed to absorb noise and vibration for a smooth ride, but do little for performance. Constructed from ¼-inch laser cut steel plate and 95-durometer polyurethane bushings, our F-Body motor mounts offer uncompromised strength and rigidity. The BMR Polyurethane Motor Mounts (MM340) drastically decrease engine movement by replacing the soft rubber bushings with stiffer polyurethane bushings with little change in NVH. The MM340 Polyurethane bushing also allows the engine to react quicker, as compared to the factory rubber bushings. BMR has designed the MM340 for street performance and drag racing applications. Installation time is 2-3 hours. Available in red or black hammertone for long lasting good looks. Proudly made in the U.S.A.
To preview all of BMR’s high-performance suspension parts, please visit
www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR
Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
__________________
Glenn ***
Sales Tech
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
