Lifetime billet high flow oil filter for LS1/LS6/LS2 !!!
-Cleanable and reusable
-Proven technology
-High flow rate
-Superior filtration
-Easy filter element inspection
-Unaffected by water, heat, pressure
-Environmentally friendly
The filter element is made from medical grade, type 304 stainless steel micronic filter cloth providing unmatched protection against oil contamination and resultant engine damage. a one inch square of this material flows an incredible 1.9 gallons of oil per minute at only 1 psi pump pressure. The adhesive used in the filter assembly process is good to 600 degrees fahrenheit, far above normal engine operating temperatures. a super strength nickel-plated neodymium rare magnet, is installed in the top of the element for magnetic prefiltering of the oil. The unique twist lock design allows for easy disassembly, inspection and cleaning. The quad-ring gasket doubles the seal between the filter and the engine. Finally the filter housing is carved out of a solid chunk of 6061T6 billet aluminum, which not only looks trickbut aids in dissipating heat. Comes with instructions and tool for installation and removal.
You will never need to purchase an oil filter again !!!
You can order online at www.neweraperformanceparts.com or call in during business hours at 585-865-1832.
-Proven technology
-High flow rate
