SLP 2005-08 C6 Corvette Hood with Functional Scoop
LS1TECH Sponsor
NEW! AVAILABLE NOW!
SLP P/N 100012
SLP now offers an all-new C6 composite hood with functional scoop to fit 2005-08 Corvettes. This OEM quality C6 hood is manufactured using the same RTM process that SLP used when manufacturing over 52,000 hoods for the Camaro SS, Firehawk and WS-6 specialty vehicles for GM and its dealers.
This aggressive, functional hood will set your Corvette apart from the rest. The hood is designed to force cold fresh air into the engine compartment, forcing out hot under-hood air. Manufactured using an OEM-quality resin transfer molding (RTM) process, providing a stronger, more durable hood.
An internal water control system is built in to the hood, preventing rain and snow from getting onto critical engine components. OEM-style crush initiators are also molded into the hood, typically not found in aftermarket fiberglass hoods.
The hood is shipped ready to prep, prime and paint. All necessary hardware, detailed instructions and a serial numbered authenticity plate are included.
SLP's C6 composite hood includes the following features:
For more photos, pricing and ordering information, please visit this product page at: http://www.slponline.com/view_produc...2&BIG=100012-1
Thanks,
Team SLP
SLP P/N 100012
- OEM styling, safety and performance benefits typically not found in aftermarket fiberglass hoods
- OEM quality composite material utilizing RTM (Resin Transfer Molding) process.
- OEM style molded-in crush initiators.
- Same weight as stock OEM hood.
- Fully functional scoop forces cold air into the engine compartment, extracting unwanted heat.
- Internal water control system prevents rain and snow from getting onto critical engine components.
- A permanently attached serial numbered authenticity plate.
- Coated inner hood hardware with bump-stop receptacles.
- Accepts factory inner hood liner (needs to be cut to keep hood scoop functional).
- Easy, bolt-on installation requiring no modifications and maintaining all factory gaps.
- All hardware and installation instructions are included.
- Factory matching 3 year/36,000 mile warranty covering materials and workmanship.
Thanks,
Team SLP
