do i need a better fuel pump or a stand alone fueling system
....would i need a better fuel pump or a stand alone fueling system if im gonna do a big 250 shot of nitrous on a 408? If so do we have any sponsers that sell these .. ?
harris speed sells a decent stand alone for a good price. I would run one on that big of a shot as buying 5 gallon drums of race gas to mix gets expensive and hard to get exactly the right mix. With the price of race gas I would definatly look into it.
Guest
Posts: n/a
We offer a very extensive line of dedicated fuel systems.
http://www.nitrousoutlet.com/catalog...del=73&dept=11
Nick
What are you making on motor at this point.. I see this is going in a truck. I can custom build you a dedicated to feed just the nitrous or a system to feed both motor and nitrous if it would better fit you needs.
Dave
Dave
You need to do both . There is no cheap away around it. The 408 will demand a better pump depending on how much power your making na and you will have to get a stand alone for the 250 shot of spray. I had to do both for a stock bottom end 346 with spray. You don't want to chance going lean so just do both and get it over with and be safe than sorry.
