how long would a tank last on 150 shot
I have sprayed my 150 shot about 6 or 7 times on the track.
When I was doing it at that time I was not sparying in 1st, so that was probably why I could get a few more then others.
But after spraying 1st, I was seeing about 4 good 1/4 mile runs before I noticed a big difference in the hit.
10 seconds of a 150 shot will use 1.2 lbs of nitrous. so if your bottle is full and properly filled you should get around 8 full pulls on a 10lb bottle or 7 runs if your car is not as fast
