drill tap TB for nitrous nozzle?
Old Oct 19, 2008 | 05:29 PM
tording99Z28's Avatar
Default drill tap TB for nitrous nozzle?
I am setting up my wet nitrous kit on my 99 Z28. I am trying to decided where to plumb my nozzle in at and I have the stock accordian style bellow which I don't think its solid enough to hold a nozzle and not have the nozzle twist and turn inside it. My question is can I drill a hole in the throttle body on the very edge farthest away from the blade that I can get and tap it and thread my nozzle in there? The only thing I am worried about here would be good distribution but I am not going to spray under 2700 rpm anyway so what do you guys think?
Old Oct 19, 2008 | 06:01 PM
HotRod68Camaro's Avatar
Like you said i dont think distribution would be any good. Best bet is going to be to get a smooth bellow, instead of that accordian.
Old Oct 19, 2008 | 06:03 PM
ttranssam's Avatar
why not go into the back of the mass? thats were im plumbing mine in....
Old Oct 19, 2008 | 06:41 PM
Even the smooth bellows though are just a rubber or plastic and I don't think they will be rigid enough to hold the nozzle and not have it twist and spin.
The back of the MAF is not a bad idea though, I never thought of that. That would give enough distance that distribution would probably be better. Anybody think of any reasons why that would not work?
Old Oct 19, 2008 | 07:10 PM
blockheadnic's Avatar
Thats were mine is located worked pretty good, has never backfired under 3k launches. plus i think you can get a maf cheaper then a TB
Old Oct 19, 2008 | 08:05 PM
http://www.nitrousoutlet.com/catalog...roduct_id=2719 Thats what i use though mine is in hard plastic.
I agree though the back of the MAF would be great.
Old Oct 19, 2008 | 08:09 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
drill and tap the back side of the maf or get a nozzle adaptor fitting. either way is accepatable. I would not tap the throttle body just my opinion.
Old Oct 20, 2008 | 11:07 AM
Nick@HSW's Avatar
Believe it or not, I have done a few in the stock bellow and its not as bad as you would think. If you're still concerned about it, I would go slightly back more and hit the backside of the maf housing (end closest to throttle body). You can drill and tap that for a more solid foundation. Or, I don't know if this is an option for you but maybe a reinforced smooth bellow with nozzle retaining nuts? Thanks.
Nick
Old Oct 20, 2008 | 11:10 AM
streetassasin's Avatar
mine is in the stock accordian bellow and it is fine
Old Oct 20, 2008 | 12:18 PM
transam69230's Avatar
I ran mine in a fernco bellow from home depot for over a year and a half and never had any problems. Just like Dave mention get some rentention nuts the screw together from the inside and out, holding the nozzle right in place.
Old Oct 20, 2008 | 01:02 PM
Thanks for the good ideas guys. I didn't even know they made those nozzle nut things to help hold them, thats a good idea. I think I might get one of those and a smooth bellow. Where do you all recommend I get a smooth bellow from that looks good? Something in black would be awesome.
Old Oct 20, 2008 | 02:27 PM
Home depot fernco bellow, it is in the plumbing section. It works like a charm and they are cheap too if you mess it up just spend another $8 and get a new one. Look in the external section there is a sticky that tells you what you need to know.
Old Oct 20, 2008 | 02:45 PM
LSXFORMULA99's Avatar
i have a rubber smooth bellow and my nozzle is on it. it works great! doesnt twist or anythng.
