Need Help..how To Make 2 "5lb" Bottle Work
Old Oct 19, 2008 | 11:53 PM
SPEEDYTRANSAM1996's Avatar
Default Need Help..how To Make 2 "5lb" Bottle Work
I was wondering how 2 5lb bottles work at once. What kind of set up is needed cause my cousin has 2 5lb bottles and wants to toss them in his trunk. I told him to get a 10lb but for some reason he wants to keep these. So im here to ask how to make them fully functional. Will they make the same pressure also? Can 1 bottle warmer be wrapped around both?
thanks
Old Oct 20, 2008 | 12:49 AM
00cls1camaross's Avatar
2 automatic bottle heaters would be good, so they would heat them to a psi and then turn off. this should keep the psi fairly close, all you need it a T or Y fitting and connect all the sides of them together and it will work
Old Oct 20, 2008 | 06:20 AM
icen's Avatar
heres my setup
