what kit? LME 408
It all come down to what you want, plate, nozzel, and direct port. As far has how much spray your LME 408 can handle. You may want to give Bryan a call at LME an talk with your builder. It all comes down to what crank, rods, pistons, and RING they used in the build-up.
http://www.harrisspeedworks.com/shop...age=1&featured
Our plate kits will easily handle up to a 200 shot and can go well over that if needed. we offer a complete package that includes everything you need to run the kit safely and get the expected performance out of the kit.
http://www.nitrousoutlet.com/catalog...roduct_id=2794
The link is to a 78mm plate, but it would be the same price for any of the LSx plates we have in stock. 78mm, 85mm, 90mm, 92mm, and 100mm.
Nitro Dave has good kits, can't go wrong with his products. Won't be breaking the bank, either. I'm partial to NX but i have direct port. If you think you'll be spraying over 200 down the road (if you keep stepping it up) then I would go ahead with a DP system and be done with it. Do it right the first time, then all you have to do is change the pills to the size shot you want. Your choice. If you want to save some $ and dont think you'll spray more than 200 just get a plate kit. If you want the ability to eventually spray bigger, DP is the way to go.
Nick
