TR6 question??
Old Oct 27, 2008 | 09:46 AM
brad8266's Avatar
Originally Posted by sixpack_2_go
i didnt know if their was some kind of tuning he could do to make it safe? i.
Add fuel and/or reduce timing helps for safety but there still is no reason not to run the colder plug though.
Proper tuning and proper parts is the key, its not one or another. You can have cold plugs and shitty lean tune and still blow a motor and you can have a decent tune and stock plugs and still melt a plug. Im sure you can get away with stock plugs for a little bit but why even risk it??
Old Oct 27, 2008 | 09:53 AM
allmotor's Avatar
Originally Posted by brad8266
Why even bother asking us if you arent goiong to listen. Go ahead listen to your expert tuner and run a stock plug then. Dont complain when you melt a plug or ruin your engine when you simply could have replaced your spark plugs. TR6's run fine NA also so theres no reason not too.
If you search around here there are instances of guys running stock heat range plugs and ruining their engines on spray.
I run TR7's @ .035 with a powerglide, 4.10's and 5500 stall on the street no problems driving on the street at all
Old Oct 27, 2008 | 09:57 AM
Nick@HSW's Avatar
You need to side with caution on nitrous. I cannot stress that enough! I see people looking to do obnoxious shots through single nozzles, plates, etc. and all I can do is give my suggestion and its up to the persons involved to decide if its the right direction for them or not. And that's exactly what everyone in this thread is doing so far, recommending to be on the cautious side. I highly recommend dropping heat ranges on the plugs. And I HIGHLY recommend not spraying the platinum tip plugs. If you have any questions as to why, please by all means just ask. Thanks.
Nick
Old Oct 27, 2008 | 10:53 AM
SURPRYZ's Avatar
Would changing the gap on a spark plug after a car has been tuned effect the tune?
Old Oct 27, 2008 | 11:36 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Nick
Old Oct 27, 2008 | 12:28 PM
brad8266's Avatar
Nope.
Old Oct 27, 2008 | 12:42 PM
sixpack_2_go's Avatar
i didnt say i wasnt going to listen. i will be running the TR6. i was just trying to see if someone knew something i didnt about the tuning becase i am unfamiliar with what all can be done through tuning.
Old Oct 27, 2008 | 12:44 PM
Originally Posted by SnakesRslow
I have no idea why he would say that but, i would deff run at least a tr6 around .035 not really any tuning that can lower cylinder temps like that unless he plans on running no timing and a lot of fuel.
on a side note the only problem ive had with my ngk's is running a shot and torco, they dont really seem to like each other
wats torco? is it a fuel additive?
1979transam's Avatar
TR6 are something you must have on spray, save yourself the trouble and buy you a set
Old Oct 27, 2008 | 02:06 PM
SURPRYZ's Avatar
Nope.
Thanks
Old Oct 27, 2008 | 07:52 PM
brad8266's Avatar
yeah.
Old Oct 27, 2008 | 08:00 PM
  #32
waterbug1999's Avatar
TR7's here..
Old Oct 28, 2008 | 04:43 AM
  #33
JL ws-6's Avatar
Race your car!
I wouldn't run any of that fuel aditive crap, if you need more octane, buy the damn fuel!
Old Nov 2, 2008 | 10:07 PM
  #34
Jordan S.'s Avatar
he is a very good famous tuner.
Just wait til he messes up your stuff. You'll learn.
Old Nov 2, 2008 | 11:40 PM
  #35
FOR THE LAST TIME!!! I HAVE THE TR6'S IN MY DAMN CAR!!! I JUST WANTED TO KNOW IF ANYONE KNEW WHY HE WOULD SUGGEST THAT!!!! I NEVER SAID I WASNT GOING TO RUN THEM!
Old Nov 2, 2008 | 11:57 PM
  #36
1996camaross's Avatar
tr6's are the way to go.... switched mine about 2 weeks ago!
